Monitor Advice
Fist3365
I am going to be upgrading my current monitor soon and I would appreciate advice on which direction I should go. I don't know if I should go with a high speed gaming monitor or a 4k monitor. I am looking at the Benq XL2730z (which hasn't been released yet) or a Samsung 4k monitor (which hasn't been released yet), and of course freesync as the main deciding factor. The XL2730z boats 1ms response time, 144hz refresh, 2560 x 1440 resolution, and a TN panel. The upcoming Samsung freesync monitors are the UE590 and the UE580, if I'm not mistaken, with 1ms response time and 60hz refresh. I called up Benq and they didn't confirm the price yet but they hinted it would probably be about $600. I am assuming the Samsung monitors coming out are about $600 as well.
I mostly play FPS and RTS games when I am gaming. I am hesitant on spending $600 dollars for the XL2730z if a samsung 4k monitorwill be the same price, but I would spend that much if the XL2730z is that good when it comes to gaming. I am also not looking to get any IPS monitors at this time. Any advice is apprecaited.
I currently have:
Asus Crosshair v Formula z MOBO
Sapphire R9 295x2 GPU
Benq GL2460 monitor.
I7-6700k OC'd 4.6 // Asus ROG Maximus Hero 9 // ROG GTX 1080ti OC //Corsair LPX DDR4 32gb 3ghz // Corsair AX 1500i // 1tb Samsung 850 EVO // 256gb Samsung 850 PRO for OS // Windows 10 Home 64
9 REPLIES 9
1sthurricane
I personally am not sold on true 4k monitors yet(But I have a 4k Samsung tv),I have the rog swift which I love.I play FPS's and RTS titles(BF4/Attila) etc.I prefer what gives me the best refresh rate/FPS .....and 2k gaming for me has been a blast compared to my older Asus 1080 60hz monitor or a 4k monitor that refreshes @60hz.
uofaboy
I'm gonna have to agree with hurricane, Windows currently does not scale very well in 4K, images and text look sharp but very small in alot of instances and you'd need a major gpu investment to even get the same playable/acceptable framerates from a single gp on a 1080 or 1440p monitor. I've had a 13" and 15" laptop with 4K which I ended up returning because the benefits for me so far don't outweigh the negatives.
ChiefZeke
Been running Samsung SyncMaster U28D590D (Display Port) [28" Ultra-High Definition LCD] for months - very satisfied. Rest of system listed below.
Lian-Li PC-A77F Full Tower case
PC Power & Cooling Turbo-Cool 1200 ATX12V & EPS12V PSU
ASUS Rampage IV Extreme LGA 2011 X79
Intel Core i7-3960X 3.31 LGA 2011 CPU
Intel RTS2011LC Liquid Cooling Solution
Kingston KHX24C11T3K4/32X (quad 32Gb memory kit) 2 each
ASUS Radeon HD7970 DirectCUII 3Gb GDDR5 PCIe 3.0 x16 Video Card (two in CrossfireX Mode)
Western Digital Cavier Black 2Tb SATA III 6.0GB/S
OCZ Technologies Vertex 4 SATAIII 6Gb/s 512Gb SSD
Thanks for all your replies, thus far. I think I am leaning towards the Benq monitor xl2730z. Do you think I will notice a big enough difference from my current monitor (Benq 24" GL2460.... entry level monitor) and going to the Benq xl2730z (27" 144hz // 1 ms //...etc)? $600 is more than I wanted to spend on a monitor, but if it is a big enough step up in gaming...then I will probably get it. Also, if you guys think there is a better monitor manufacturer out there, then I will look at them instead of the Benq.
Fist3365
I chose to go with the Benq XL2730z monitor and I'll see how good it is when it arrives next week. I think I will enjoy higher refresh rates than the UHD monitor at this time.
NemesisChild
Level 12
Enjoy that 144Mz monitor, you won't regret the decision.
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
cybacreep
i am Enjoying 144Mz monitor
[SIGPIC][/SIGPIC]
I just received the monitor a couple hours ago and it is built with heavy quality components. So I have my monitor setup to 2560, 1440 // 120hz and I was playing COD AW and it is noticeably more smooth now. Of course I came from a 24" 1920x1080 monitor so this Benq XL2730z is physically bigger. I tried selecting the 144hz option and the screen flickers like crazy, but 120hz works great. I read in some other forums that this will supposedly be fixed when AMD releases their new Catalyst driver (sometime today). If that doesn't work their is another fix recommended that I will try. Until then, I can't be happier. One other point to be made, Freesync isn't technically working on my monitor yet since AMD will release the single GPU driver today and because I have the R9 295x2 GPU that driver won't be released until sometime in April. I'm still excited with my purchase!
1sthurricane
Glad to hear all is well,I am running two Sli 980's and using G-Sync and have the Rog refreshing @120hz for BF4.120hz seems to be the sweet spot for me.Congrats buddy!
