MOBO and Graphic compatible help
John_Sotiriadis
Can u please help me. I went to your website but i could not fill all format because i cant remember some info. I have the Motherboard Asus Rampage 3 Extreme with a Nvidia GTX470 graphic card. I want to upgrade my machine and get the Nvidia GTX770. But on the site the motherboard it says it is PCIe 2.0 and the graphic card it is PCI Express 3.0. I wanted to make sure if it is going to be compatible, i find forums that it says it is but i want to make sure before purchase it. thank you for your time
11 REPLIES 11
Chino
Level 15
Welcome to the ROG forums, John_Sotiriadis.
PCIe 3.0 is backwards compatible with PCIe 2.0. You'll have no problems running a GTX 770 on that motherboard.
John_Sotiriadis
and after the summer i was thinking getting 1 more GTX770 and SLI them, would u recommend it or? i mean 2 GTX770 is better than 780 and TITAN and 690 are 2 expensive for me
Chino
Level 15
John_Sotiriadis
faster than TITAN? not sure tecnicaly yes u get double performance but mostly SLI told me u get about 3/4 the power of cards or bit more, but not max. Anw again thanks mostly for motherboard will order next week
Here's a nice GeForce GTX 770 SLI review so you can look at the numbers.
HiVizMan
Level 40
If you want to compare stuff like this go over to the Anandtec site and look at the bench section. They have all the recent graphic cards to compare.
Yeah, Anandtech's bench section is great as far as GPUs.
I wouldn't use their CPU bench chart, because they're missing a lot of chips.
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
John_Sotiriadis
ok one last thing i already order 1 gtx770, but after summer will get 2 for SLI. The heat will be problem? or will be at the same lvls of 1 gtx470 ( and those people say do get heat a lot)
Chino
Level 15
If there is adequate clearance space between the GPUs and the airflow in your case is optimal, they will be fine.
