03-21-2018 10:05 PM - last edited 3 weeks ago by ROGBot
03-21-2018 11:44 PM
03-22-2018 10:28 AM
Nate152 wrote:
Hi won_chulupa
Welcome to the ROG forum !
Connect the pump to the AIO_Pump header, for the two rad fans get a Y splitter and connect them to the cpu fan header.
How many case fans in total ?
If only 2, get another Y splitter and connect them to the chassis fan header. If more than two, make sure the total number of fans do not exceed 1 amp or 12 watts. If they exceed 1 amp then you have no choice but to connect some to the psu or go with another motherboard. It's always good to let a little head room and not max out the fan headers.
03-22-2018 06:38 PM
won_chulupa wrote:
I'm pretty sure the sata has to be connected for power.
won_chulupa wrote:
But the fans can be either connected to the pump or like you said with a y-splitter to CPU_FAN?
won_chulupa wrote:
And yes I am planning on two additional case fans for exhaust. Will the CHA_FAN be controllable thru BIOS (swpeed-wise)?
03-23-2018 11:35 AM
