11-22-2025 03:06 AM
I recently bought a x870e hero
Cpu and 9800x3d
Ram 48 gigs of tforc ddr5 8000
It is getting stuck in memory training on the initial boot I have only the bare essentials for the computer to power on plugged in my aio the power to the motherboard and the power to CPU it never makes it past the memory training though. I saw some people saying let it sit for 5-15 minutes but they hasn't seemed to work. I tried to reset the CMOS on it and then update the bios as well and it hasn't made any changes. Has anyone else found a way to resolve this, or run into this?
11-22-2025 05:33 AM - edited 11-22-2025 05:38 AM
Hello Lazar93
1) Shut down your pc and unplug the power supply cable.
2) Make sure your memory is installed in the A2-B2 slots (2nd & 4th slots from the cpu).
3) Press and hold the clear cmos button for 3 seconds.
4) Try booting up your pc.
At default settings it should boot fairly quick. Does it eventually boot or still stopping on the yellow Dram led?
