Memory issue with ASUSTeK PRIME X299-A
franck_friends
I currently have have four 8gb sticks installed on the right side of the CPU.
As you might already know, there are four additional slots on the other side of the CPU.
I'm trying to add an additional 16gb single stick there but wherever I plug it it won't be recognized alongside the existing ones.
Which means that I can't surpass the 32gb barrier for some unknow reason.
The CPU ( i9-7920X CPU 2.90 GHz on Windows 11 Pro 64bits ) is a 12 cores so I don't thing the problem comes from that.
I've also tested the16gb stick alone and it's not faulty.
What do you think is going on here?
Thanks!
0 REPLIES 0
