08-05-2014
09:50 AM
- last edited on
03-05-2024
10:34 PM
by
ROGBot
08-05-2014 10:03 AM
08-05-2014 11:10 AM
08-06-2014 04:47 AM
kkn wrote:
for the nd14 you have to think about ram height.
08-06-2014 10:36 AM
Mr..X wrote:
example 4790k allows till 1600mhz without overclock and maximus VII formula allows 1600mhz without overclock,in this case i suggest 1600mhz if you are not going to overclock right away..
edited:i don't think you can use 2133mhz without overclocking,that would use less clock rate and the beast would be sealed away,if you use maximus VII formula you need the 1600mhz ram..i am still looking for an answer in my build adevice between vengeance and ripjaws x...
08-06-2014 05:58 PM
kkn wrote:
all memory abow 1600mhz is oc, and if you get a kit of 2400 it just to set X.M.P inside bios and *poff* its done.
best memory for gaming is in the range from 1866 to 2133 and maybe up to the 2400mhz range.
abow that you will not notice enny thing in day to day usage realy.
and memory slots? use the recommended in the manual ( witch will be the red slots if im not mistaken ).
08-07-2014 10:49 AM
Mr..X wrote:
thanks for the info.but if i buy 1600mhz cl9-9-9-24.can i overclock and acheive 2400mhz with somewhat comparable or non comparable latency?
08-07-2014 08:36 PM
flyinion wrote:
You could try but I highly doubt you'll be able to get 1600mhz RAM to run at 2400. There's a reason the mfr. rated it for 1600 instead of 2400. Not to say that you can't get more than 1600 out of it, just very likely nowhere near 2400. Also, here's a good post on speed vs. latency. http://www.overclock.net/t/833520/ram-faster-speed-vs-lower-timing#post_10851735
08-07-2014 08:46 PM
