I've been reading when you put a FX-8370 & Wraith cooler on a ASUS SABERTOOTH 990FX mobo, there is an issue with using full height memory modules. Evidently, the cooler overhangs the 4th memory slot just enough to where you can't use a full-height memory module.
Does anyone here have experience with this setup?
Thank You
