memory advice
danskieness
currently i have a corsair xms3 1333mhz 4gb(2x2GB) cl8 sticks and im planning on changing it because sometimes when i play battlefield 3 on ultra i ran out of memory
what type of memory would you recommend? i have no plans going above 8gig please explain thoroughly your advice thanks 🙂
oh and as much as possible i like it red to fit the color coding of MVF, possibly corsair but can also be black
CPU : i5-3570k
Mobo : ASUS MVF
Mobo : Asus Maximus VI Impact || CPU : i5-4670k || Cooling : H100
GPU : MSI GTX 970 Gaming 4G || PSU : Corsair RM 650 || Rams : G Skill Trident X 4GBx2 2400 CL10
Monitor : 2x Asus VX239h + 1x HP w2207h || Chassis : Bitfenix Prodigy Red || OS : WIN8.1 x64
Periphirals : Corsair K95, Logitech g402, Edifier 3350
11 REPLIES 11
lenehan
Try Gskill RipjawsZ F3-14900CL9Q-16GBZL (4Gx4)
http://www.gskill.com/products.php?index=434
10697
Change is the law of life. And those who look only to the past or present are certain to miss the future.
Silver_Wolf
Corsair Dominator GT or Dominator Platinum are both very good also.
Good choice too but need to beware the heat spreader as may too high for some CPU heat sink.
Silver_Wolf
Would you not have the same issues with the Ripjaws? Or are they low profile heatsinks? I confess to never having seen them aside from pictures.
But I have had this problem myself so I had to take a fan off my V6GT which doesn't really reduce its performance much.
I am running Noctua D14 and I dont have any issue. I am not being bias but GSKill work well with Asus.
10697
thank you everyone for your responses 🙂 i might go Dominator Platinum or Gskill RipjawsZ(that is if i find a stock here in the Ph)
in the mean time im still accepting suggestions but my vote is on corsair 😄 cause im kinda building an almost corsair rig
Arne_Saknussemm
Level 40
The Ripjaws fit fine under things like the NH-D14 they are pretty low profile. Dominators too fit fine if you take off the top heat-sink frilly bits, which is easy to do and doesn't affect then in any way. If you are watercooling any of them will be fine.
If you don't want more than 8 GB you could go with something like http://www.gskill.com/products.php?index=437 fast, high quality, will run as 2 dual channel kits and been tested on the MVF.
Of course there is a RAM QVL for that board maybe pick something off that.
Zka17
Level 16
Still not sure what's your CPU cooling solution... it would be important though for figuring out the memories... 🙂
My first vote would be also for the Dominator GT series... On a second thought, you may want to consider the GSkill Trident X series too... - the color scheme fits with black and red and you also could remove the top of the heatsinks..
Yes ageed that, and gskill forum support are as goog as this.
