Mediatek Wi-Fi 6 MT7921 Wireless LAN Card is not reinstalling automatically.
ItsTheMCGamer
For a while now my wifi adaptor has been disconnecting and the only way to turn it back on was to hard restart my computer twice. After much troubleshooting I decided to try to reinstall the wifi adaptor so I went to the Device Manager and uninstalled it but I tried restarting my computer after and it isn't reinstalling. Now instead of my internet cutting off randomnly, I have no internet at all! Any help would be appreciated. I have an ASUS TUF Gaming F15 FX506LH laptop.
EDIT:
To get have internet while waiting for an answer I plugged in an ethernet cable and after I unplugged it and restarted my laptop, the wireless LAN card was working again!
4 REPLIES 4
iLLKiD
Same here. Any solutions? It’s annoying as f… 😞
While making this post I plugged in an ethernet cable and when I uplugged it and restarted my computer, my LAN card was working again. Hope this helps!
BALAGURU_R
pls help me i didn't reinstall that
michellestubs03
Hey ItsTheMCGamer, glad to hear the ethernet cable trick worked for you! Saved me some troubleshooting too, thanks for sharing the fix.  If you're looking for a new place to call home in Alpharetta, check out Happy Homes Alpharetta!
