03-22-2021 05:22 AM - last edited on 03-05-2024 06:59 PM by ROGBot
03-22-2021 08:53 AM
03-25-2021 01:49 PM
05-22-2021 07:24 PM
Killersjp wrote:
Ok. After more checking there is a problem with Intel Management Engine Interface and Windows 10 fast startup option ticked in the power settings on Windows 10. Without it installed my computer boots to Windows desktop perfectly. With it installed the computer freezes with no picture during the spinning dots under the ROG logo during booting. *I then have to press the power button on the pc until it turns off. Once I press the power button again it boots ok. If I then uninstall the management engine the computer boot ok every time. I will wait for a update of the Intel software then try again. Hope this helps if someone else gets the same problem with this new released board. Thanks for reading.*
06-25-2021 08:11 AM
