Hi there,
My new Maximus XII Formular is showing a weird temp. System works without any issues....
- The hardwaremonitor of the Aquasuite shows 98C on temp#3.
- The Icue Dashboard shows 98C on temp#5
- Aida64 is not showing any temp high like this.
I am a bit confused. Does somebody have an explanation for this? Do I need to worry?
Running BIOS Version 1002, all drivers up-to-date.
Thx
Thomas
Thermaltake - The Tower 900
ASUS ROG Maximus XII Formula, Intel Z490 Mainboard - Sockel 1200
der8auer Core i9-10900K (Comet Lake) Sockel 1200 - pretested @ 5,1 GHz
G.Skill Trident Z RGB DDR4-4000 DIMM CL19-18-19-39 Dual Kit 32GB (2x 16384MB)
nVIDIA GeForce GTX 1080 Ti Strix
Samsung SSD 970 EVO Plus 1TB (1000 GB, PCI-E 3.0 x4)
Samsung SSD 950 PRO 512GB (512 GB, PCI-E 3.0 x4)
Samsung SSD 860 PRO 1TB (1024 GB, SATA-III)
Samsung SSD 850 PRO 512GB (512 GB, SATA-III)
ASUS ROG Thor 850W
aqua computer aquaero 6 XT
aqua computer Aquastream XT USB 12V Pump - Ultimate Version, OLED
aqua computer aqualis XT 450 ml
aqua computer aqualis PRO 880 ml
2x aqua computer airplex radical 2/360mm - Kupfer
Noctua NF-F12 industrialPPC-3000
EK Water Blocks EK-Velocity Intel RGB - Nickel + Acryl
Phanteks Glacier G1080Ti
