10-10-2018
07:02 PM
- last edited on
03-06-2024
07:52 PM
by
ROGBot
10-31-2018 12:23 PM
Ingvarr100th wrote:
Hi
Like topic, do I need to use or fill CrossChill water block? I'm going to buy Maximus XI Formula or Extreme.
I'm not planning use custom water solution. For CPU I alredy bought Corsair H150i AiO and I have ROG Strix 1080 Ti which it doesn't have water block.
Should I sell H150i and make custom water loop? Or just wait for Maximus XI Extreme?
11-01-2018 08:30 PM
michaelrw10 wrote:
Do you have the XI Formula? If so, where did you get it? Nobody from ASUS has been able to tell when or if it will be made available... if you do own one, you may be the first person to get one that's not a reviewer/youtuber.
Edit: didnt read your post close enough, i see you said you plan to buy it. Best of luck, let us know if you can find one. XI Extreme is supposed to be released "in the next couple months" according to ASUS support. XI Formula has already been realeased (officially), but it's more rare than BigFoot
11-01-2018 02:51 PM
11-05-2018 08:15 PM
Vlada011 wrote:
I would never left X99 or X299 chance for Z390 chipset.
Only adavantage of Z390 is Maximux XI Gene.
Rampage VI Apex is my style motherboard.
Why I can't find some i9-9820X... I could buy everything else for 300 euro.
Rampage VI Apex brand new unboxed 250 euro, 60 euro CPU block. That would be deal of year.
Special now when I have close performance to Turing with Poseidon GTX1080Ti.
I never had better and more silent GPU fans, could work on 80% speed not bother me.
73C load without liquid, this week when I put under water I expect around 60C max.
