Maximus XI Extreme Dimm.2 RAID 0 with Samsung 970 Pro nvme SSDs
Deltaphi
Hello to anyone who reads this.
I would appreciate any help in clarifying whether you can use Samsung SSDs on the DIMM.2 slot for RAID 0 bootable configuration, or does it work only with Intel branded SSDs.
Thanks for any help.
Dimitris
Motherboard: ASUS Maximus XI Extreme, CPU: Intel© Core™ i9-9900K, RAM: Corsair Vengeance RGB Pro 32GB 3200MHz C14 (CMW32GX4M4C3200C14),
GPU: ASUS ROG Strix RTX 3080 Ti Gaming OC, CPU Cooler: Corsair Hydro H115i RGB Platinum, CASE: Corsair Obsidian 650D, PSU: Corsair AX1200i,
SSD: (NVME) Samsung 970 Pro 512GB & 970 Evo Plus 1TB & (SATA) 850 Pro 256GBx2 RAID 0, HDD: WD Gold 10TB & 2TB, Black 2TB, WD My Book 8TB,
Monitor: ASUS ROG Swift PG279Q, UPS: APC Back-UPS XS 1400U
11 REPLIES 11
I don't understand which configuration is better.*
You wrote:
No, you’re OK at X8 on the GPU as the 2080Ti is the first card to saturate PCIE Gen 3.0 X8 bandwidth
This sounds that a NVLink setup with 16x and 8x makes no difference - comparison to 16x 16x
Then you wrote:
*I’m about to change it all though as after going to 2080 Ti cards they actually do saturate X8 bandwidth so I’m ditching VROC completely and using a single intel U2 drive, changing the DIMM.2_1 to PCH so I get *16 on PCIE16X16_1 and PCIEX16_3.*
This sounds that 16x 16x is better than 16x 8x.
If I check e.g. this page it seems that it makes no difference - thanks no NVLINK:
*https://www.gamersnexus.net/guides/3366-nvlink-benchmark-rtx-2080-ti-pcie-bandwidth-x16-vs-x8
I'm confused ;-)*
JohnnyFire
hey there can you help with one thing? is it possible to backup the firmaware of you aquantia lan and send it to me? it very important to fix mine
