01-20-2019
06:38 PM
- last edited on
03-06-2024
08:45 PM
by
ROGBot
01-20-2019 07:27 PM
01-20-2019 07:33 PM
btrach144 wrote:
Yes, Samsung SSDs will work. It just uses Intel RST to create and manage the RAID 0. Most NVMe drives should work without trouble. The main goal is to have 100% matching NVMe drives.
01-20-2019 09:14 PM
01-21-2019 09:19 AM
JustinThyme wrote:
Intel SSDs only apply to VROC so you don’t have to worry about that. My question is though why are you going raid0? If it’s for a performance boost you won’t see it on NVME drives as they already saturate the DMI bus as standalone. You will also take a hit on the low que depth speeds due to the latency of raid.*
01-21-2019 09:41 AM
01-21-2019 03:05 PM
JustinThyme wrote:
No, you’re OK at X8 on the GPU as the 2080Ti is the first card to saturate PCIE Gen 3.0 X8 bandwidth and only by a little. You won’t be able to do raid 0 with one in the CPU and the other on the PCH though. *Like I said though it’s pointless. If your board allows both on CPU which I don’t think it does you still can’t raid them up and make it bootable. Only way to do that is on X299 and it has to be Intel drives.
01-21-2019 04:27 PM
01-21-2019 04:51 PM
JustinThyme wrote:
Booting from CPU lanes with anything but Intel drives in VROC is not possible. Software raid only with non intel drives. *Trust me when I say all this has been tested and beaten to death. Myself and several others tried every configuration possible. *This board and it’s design are an intel chipset so they control the patent and implementation. At launch they wouldn’t even get off of what VROC keys would work and many were tried. Only one will work but it’s not needed for bootable raid zero. BUT Intel drives are mandatory. You want the speed you have to pony up. Two 480 GB drives are not all that much more than 2 1TB Samsung 970 pro drives. Yes get half as much but that’s just the way it is. The intel drives can’t be touched to random low que depth performance which is the most important of heavy workloads and OS operations. Samsung owns the large file sequential reads. My rig is set up with intel drives for the OS and general software while all games and anything with large files gets installed to a single Samsung 1TB 960 pro in DIMM.2_1 set to CPU as the source. *I’m about to change it all though as after going to 2080 Ti cards they actually do saturate X8 bandwidth so I’m ditching VROC completely and using a single intel U2 drive, changing the DIMM.2_1 to PCH so I get *16 on PCIE16X16_1 and PCIEX16_3.*
Bottom line no matter how you slice it is if you want bootable raid on CPU Lanes it must be intel drives, if you want raid on PCH you can use whatever drives you want. Search VROC X299 section, sit back grab your favorite libation and read a bit. We pounded this hard at product launch Q4 2017.*
The reference to Optane in the last sentence is optane Memory sticks. *Refer to the section in A X299 manual VROC for info about raid on CPU lanes.*
Intel isn’t about to allow the same functions on consumer or prosumer boards that are available to enterprise solutions that makes them 10 times more per machine. *If they did that we wouldn’t be having this conversation as enterprise customers would have already depleted all stock of motherboards if they can do the same at a fraction of the cost.*
By all means feel free to try it. Maybe you can outsmart Intel and share with the rest of us. I’m not optimistic on any such endeavor though.
01-21-2019 05:07 PM
