Maximus XI Extreme and Formula ?
MRBULL
i've pre ordered the Extreme because it was only like 80$ difference with the formula but i cant find any Advantage difference between the 2?
anyone have any idea?
Also not sure what this means
* When the M.2_2 Socket 3 is operating in SATA mode, SATA port 2 will be disabled.*
Im upgrading this year going with
Intel i9 9900k
Maximus extreme XI z390
EVGA GeForce RTX 2080 Ti XC ULTR
( im keeping my RAM G.SKILL TridentZ Series 32GB DDR4 3400 )
( im keeping my PSU Corsair Professional Series 1050W )
Any Toughs?
thanks
5 REPLIES 5
Menthol
Level 14
If you use a SATA M.2 drive it will disable one of the SATA ports
Extreme vs. Formula, well the Extreme is Extreme, the best of the best
Traveler08WLF
where did you preordered the Extreme? In US?
they have different sizes, and extreme has a special dimm.2 slot near the ram slots
cl-Adrian
Intel i9 9900k
Any Toughs?
thanks
Great Specs!
They main key differences is
Extreme = geared for superior overclocking (More settings)
Formula = geared towards watercool enthusiast
michaelrw10
Intel i9 9900k
Any Toughs?
thanks
where did you preorder the extreme from i cant find it? thx
MRBULL
it was memoryexpress but since it's only coming in december i choose formula
