10-20-2018 12:43 AM - last edited 3 weeks ago by ROGBot
10-20-2018 03:14 AM
10-20-2018 04:05 AM
10-20-2018 11:55 AM
11-10-2018 09:07 AM
Haywood74 wrote:
I am having similar issues with a XI Hero fitting into a Corsair Obsidian RGB case. When I drop it on the alignment peg, the bottom 6 holes line up perfect. Top 3 holes are off 1-2 mm toward the front of the case...I can't figure it out....
11-25-2018 04:31 PM
willburstyle06 wrote:
Did you ever figure out a solution? I am having the same issue fitting the XI Hero into my H440 case. The IO shield is preventing the top 3 holes from aligning[/QUOTE
I have the same problem but with the 390 series Maximus XI board, see my post @ https://rog.asus.com/forum/showthread.php?106464-ASUS-ROG-z390-Maximus-XI-Hero-(Wifi)-Does-NOT-fit-i...
I took it to a local computer shop, they tried 5 different ATX cases from InWin, none will fit the z390 board.
I was advised to return it and buy an MSI instead, the computer shop called it a cheap and poorly manufactured board...
The only case I was able to successfully install it is in the cheap ass ThermalTake Versa H24 (https://www.amazon.com/gp/product/B00OFR33OO/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1). However, that case has limited space for a 164mm cooler and barely can house a single 120mm watercooler
ALL ASUS Z390 BOARDS NEED TO BE MANUFACTURER RECALLED!!!!
11-25-2018 06:06 PM
11-25-2018 06:33 PM
Menthol wrote:
You should be able to push the top of the board against the back of the case to insert the screws, yes it is a tight fit but I have been able to install these boards in Corsair, Lian Li, NZXT cases
12-08-2018 11:02 AM
