MAXIMUS X HERO / 8086K Delidded questions
Asryan
Hello,
I have a maximus Hero X and a delidded 8086k and i was told that my idle temps are a bit high..
My rig is :
Motherboard: Asus Maximus Hero X
Processor: i7 8086kdelid - 4.8Ghz @ 1.2vcore
GPU : RTX 2080 TI EVGA FTW3 ULTRA
Ram : 32GB G.SKILL Trident Z RGB / 3466Mhz
PSU: Corsair RMI 850 GOLD
Watercooling : Corsair H150i Pro RGB / LL 120 RGB
Case : Cooler Master H500M
Around 37c, room temp is 24 to 25c those days.
During gaming it's all good for what I know, around 55 to 58c MAX on the hottest core. With an average around 45c
I was wondering if it's ok and maybe if some tweaks in bios could reduce the idle temps and thus help me reduce the fan speed for silence when not gaming 🙂
Also, i was wondering about changing my AIO which is a bit noisy at idle (the pump), i was interested into the rog ryujin, will it be an upgrade or samish? (i think the pumps are similar)
Thanks for the help
12 REPLIES 12
Asryan
Why is Vcssa set up at 1.1 in bios but i read it between 1.12 and 1.128 in hwinfo?
Arne_Saknussemm
Level 40
Not sure to be honest...that rail has it's own LLC and some variation is to be expected...it's not much of a difference
Sorry missed your last post....mem can get hot....maybe airflow is not as good as it could be?...but it's within spec...so...
Asryan
OK thats all good then, thanks 🙂
