06-13-2018
11:09 AM
- last edited on
03-06-2024
08:26 PM
by
ROGBot
06-25-2018 02:25 AM
06-26-2018 07:10 PM
ExGreyFox wrote:
Hello all,
I posted in another thread regarding a new build centered around the Ryzen 2700x but after more research I have settled on the 8700K and Maximus X Formula
Wanted top run this parts list by you guys:
CPU: Core i7-8700K
RAM: G.Skill TridentZ RGB 32GB
MOBO: ASUS ROG MAXIMUS X FORMULA
GFX: GTX 980Ti for now (Re-Unisg my exisitng GPU until 1180 comes out)
Cooler: NZXT Kraken x62
Storage: Samsung 970EVo NVMe M.2 500GB (OS) + Samsung 970EVo NVMe M.2 1TB (Games)
PSU: Corsair AX1200i 1200 Watt (Re-using Old existing PSU)
OS: Windows 10 Home 64-bit
I absolutely need 32GB RAM for flight simulator use.
A few concerns:
1) Can you please recommend a 32GB kit from the G.Skill TridentZ RGB line? Should I get 2x16GB or 4x8GB, which is best?
2) Will the NZXT AIO Kraken x62 be sufficient for the 8700k and hitting 5GHz or should I go with x72 ?
3) I did not see the SAMSUNG 970 Evo PCIe NVMe M.2s in the QVL for the Maximus X Formula. Will they work?
Thank you!
07-09-2018 03:26 PM
07-18-2018 12:27 PM
