First of all, it's not advisable to run 2 separate memory kits, even if it's the same brand & model.
If you want 32GB total, buy one 4x8 or 2x16 GB kit.
Each kit is designed and tested to run in dual or quad channel.
I've seen ASUS tech support advise to update to each in order of bios release.
However, you should be fine updating to the latest regardless of which version it came with.
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
