Looking for some help please. Had a space conflict with my I/O shroud and a radiator on a new build and had to remove it. I hated losing the shroud and its RGB MAXIMUS IX splash though, so I decided to re-purpose it as a M/B connector shroud:
I'm doing wire management, and I'm looking for help on the connector type for the header marked RGB_LED_STRIP_2. It's 5 pin connector and has a pin pitch tighter than a pwm fan or aura rgb header. Thoughts? I need to extend the cable length to the shroud and would prefer not to splice in wires. Thanks for any help.
