Maximus IX Extreme Thermal Pads and Monoblock Mounting Screws
fragilityV1
I just bought a Maximus IX Extreme and found the thermal Pads and monoblock mounting screws were missing. Anyone know where I can order small spare parts like this? Maybe can find some thermal pads, but don't know the thickness. And as for the screws, they seem a little harder. Would need to know the size and thread (and would have to find some with springs). Reached out to support, but never heard back.
BigJob
ebay search term "asus thermal pad" "asus screws" knowing the size def helps here. Post a pic here to see if any members here can help you figure out the size of the screws.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313.TR0.TRC0.H0.Xasus+thermal+pads...
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR10.TRC0.A0.H0.Xasus+screws.T...
or maybe this and see if they have compatible parts https://www.ebay.com/itm/asus-maximus-ix-code/173203155481?hash=item2853b66a19:g:G94AAOSwBiBaoRJc
