Maximus Hero X no enter to bios
-bender-
The monitor is connected via dp. Samsung c24fg73fqi, gpu GTX 1060. The image appears only when the OS boots. If you connect via hdmi then you can go into the BIOS. How to make it possible to go into the BIOS through dp?
10 REPLIES 10
Menthol
Level 14
Please list all your hardware,
Is this from Intel on die GPU (motherboard header) or a discrete Graphics card
List any bios settings you have changed from default
Bios default setting.
i7-8700k
ASUS ROG MAXIMUS X HERO
PALIT PA-GTX1060 JETSTREAM 6G
CORSAIR Vengeance RGB CMR16GX4M2C3466C16
Corsair RMi 750W
SmartBuy Ignition 4 240GB
Samsung C24FG73FQI
Asus Rog Strix Evolve
Corsair Strafe Cherry MX Silent RGB
Menthol
Level 14
I assume you are using the GTX 1060 and DP cable that came with the monitor
Have you tried the DP cable in a different port on the GTX 1060
Yes, I tried, the picture appears only once after the start of the de-energized system.
Chino
Level 15
In the bios falls, the problem is that there is no image.
csm is disabled in bios?
Enabled
