Maximum X Hero question
Homeuser
Hi, I am buying the Maximus X Hero MOBO. I have 2 questions:
1. The 2 USB ports on the MOBO Keybot port & USB Flashback port, can they be used as normal USB ports for peripherals? If not, what do they do exactly?
2. What is a Hyper M.2 x4 PCI Expansion card? What does it do, speed up the HDD?
Thanks!
Silent_Scone
Super Moderator
1) Yes, they can be used as conventional USB 2.0 ports
2) It is as described, an expansion card that lets you install an M.2 drive into a PCIE slot. No performance benefit.
