12-07-2013
12:10 PM
- last edited on
03-06-2024
06:42 PM
by
ROGBot
12-07-2013 12:26 PM
12-07-2013 03:31 PM
Elixire wrote:
questions:
1. does the components i have above would work to its optimized performance?
or would i encounter any bottle neck with my build? <- only bottleneck is the slowest part, are you going for SSD or HDD??
2. what do i need to do to ready the system to ivy bridge-e, i heard of BIOS flashing,
is there any other software upgrade needed aside from it <- unless it have one of the newest bioses you dont have to flash, it all depends on the bios you need, the bios that follows the board is on a sticker on it.
3. can i overclock ram to hit the maximum of 2400MHz as supposed to the specs on the board? <- if you know how to so so then yes mabye, but in real life performance you will not notice enny thing, and do remember that you need quad channel memory on LGA2011, and do not mix whit other kits, always buy the amount you need.
4. would i be able to get a stable everyday use of 5Ghz for my CPU by over clocking in this board? (i would use Thermaltake
water 3.0 extreme close loop cooler) <- that is ALL up to the processor and how happy it is to OC, its a lottery so to say, some can oc like a pro and some you may not go past 3.8ghz, so it depends on how lucky you gona be on the CPU.
5. kindly link guides on this forums if you know one. <- guides of what??
12-07-2013 04:21 PM
12-08-2013 07:53 AM
12-08-2013 09:46 AM
