LIquid Forming on the radiator fan.
Flint018
Hi
Just wondering if i should worry about liquid forming on radiator fan on my Cooler master liquid aio cooler? i check if theres a leak and i found none.
alyraver
I would certainly get that looked at asap. You don't really want any liquid dripping onto any part of your system.
Sounds like you have a leak tbh
800D/Asus Rampage IV Extreme Black Edition/i73930K @ 5.2/ Kingston Hyper X Beast 32GB 2400/ STRIX 1080TI OC, EK Nickel Plexi CPU block, No Rad + No Fans :D, Alphacool D5 Pump.. HC 500A chiller @ 4C - Max load temp @ 5.2 = 55c. Lowest Core Idle Temp = 3c
