LED's slowly flashing on Prime B350-plus motherboard
des480
Hi All,
Upgrading my PC after a number of years. I use a Prime B350-plus mothrboard, Rysen 5 1600 processor, 16gb ddr4 memory, an ssd as my boot drive and a couple od HDD for game storage. My problem started when I decided to get aan m2 pcie 500gb card. Fitted this and after somehassle managed to clone from my SATA SSD drive. Removed the old SSD ( formatted first to remove everything. Machine boots and works OK but the LED's keep cycling on the motherboard. I realise the m2 card wont show up on the SATA list cause its a PCIE card. Cant see anything wrong in the bios and machine seems to run OK. Any ideas on the LED flashing.
des480
My bad, i had reset bios back to defaults and didn’t realise default led setting was breathe. Set back to constant now so no faults.
