Led in Mother Board x670e Plus WiFi
MultMen
Hello everyone, everything good,
I would like to ask if this is normal on the Asus Tuf Gaming x670e Plus WiFi board, when i turn on  the power supply not the PC, with PC off the motherboard has the LED on the TuF as per the video in the link . But the Desktop is completely turned off with only power from the source. For this light to go out, I need to turn off the power from the Source. Is this really the case or is it some kind of configuration or is it really a problem?
Nate152
Hello Multmen
It's not a problem, you can leave the motherboard LED's on if you like.
You can configure the motherboard LED's to turn off with Armoury Crate.
Or, in the bios, Advanced tab, APM Configuration, set ErP ready to Enable (S4+S5).
Both of these options will turn off the motherboard led's when your pc is shut down.
