Lc 360 rgb
lostjonny
I had to replace my lc due to component failure, I'm running asus crosshair v1 hero, The new lc is the strix lc360 rgb. I have had some issues installing this cooler into my corsair crystal 570x and have had to make several modifications. I'm now at the point of connecting the rgb, but the motherboard rgb headers are 4pin but the lc360 has 3 pin rgb connectors, I'm really hoping that asus has not changed the standard from 4 pin to 3 pin & if they have is there a work around. Thanks
0 REPLIES 0
