Kaby Lake @ 5.0GHZ and above, Yes it does
Menthol
Level 14
It has been reported that the new Kaby Lake 7700K CPU's can overclock to 5.0 on 1.35 volts
Without giving to much information my retail sample 7700K can run RealBench 2.44 at 5.0 at 1.35 volts easy, can validate @ 5.1 1.35 volts, locks up at 5.2
Not sure if I have a good chip or not but pretty excited to play with this new chip
Haven't delidded it yet like all my Skylake CPU's are and the temps it hit running RealBench @ 5.0 with a Corsair h115i I may not, mid 70"s on open bench table
Supposedly the IMC has been improved and runs memory at high speeds, I will be checking this out soon, this is on a an ASUS Z-170 board
61402
69 REPLIES 69
Menthol
Level 14
quark54
There's an interesting feature with Kaby Lake so I understand... if it detects you're running AVX instruction sets it compensates and reduces voltage. So no more issues with AVX causing the CPU to over volt and thus overheat, with adaptive voltage.
Menthol
Level 14
The AVX offset option is in bios 3007 for M8E, similar to BW-E on X-99 boards it defaults to zero offset and you enter the desired offset you want to down clock to when an AVX load
The offset is a CPU multiplier, if you are overclocked using a multiplier of 50 for 5.0GHZ and enter an offset of 2 it will downclock to 4.8GHZ when an AVX instruction is detected, allowing a higher stable overclock for gaming
jab383
Some good and some bad in those pictures. Neither Extreme nor Apex appears to have NVMe nor U.2.
There are also no switched to disable PCIe sockets. I'm guessing that two of those sockets run PCIe3 from the CPU for one of 16 lanes or two of 8/8. With the other two sockets of different color, they are likely from the PCH.
There would not be any value in an integrated water block for an extreme cooling overclocker. For me, I would have to see the details and compare with the top-grade CPU blocks. The advantage appears to be that the integrated block cools the VRMs. Sort of like mixing an Extreme with a Formula.
Maybe back of board?
EDIT:
Scanning pics....does it say "M.2_2( SOCKET 3 )" here?
61548
Menthol
Level 14
ASUS has done away with SATA express and U.2, glad they did
The Extreme has 2 M.2 slots one under the bottom of full block, water cooling for your M.2 drive, second is under the bottom of the PCH heatsink where Arne pointed out, the block looks fantastic if your building a daily use water cooled system, maybe the block will be optional, or maybe the standard VRM heatsinks are included, we should know pretty soon
I haven't used sli on my M8E and have never used the pcie lane switches except on the big platforms, X-58-79-99, wish they would add pcie switch for M.2 drives
The Apex is really a pro bencher board, so probably not necessary to have M.2 but it may on back of board, only 2 ddr4 slots for highest memory speeds and a single ddr3 when you tuned the memory to far and it won't boot flip a switch and boot to the ddr3, seems like an LN2 dream, maybe not my cup of tea but I am glad to see a board designed with extreme OC without the gaming extras attached
Would like to own either board myself but the Extreme model has always been my preferred board regardless of platform
Another tidbit the Apex board has a M.2 board that slots into the ddr3 slot wired to the PCH, not what I first read about booting to a ddr3 memory module when memory overclock fails
61558
More info available here http://edgeup.asus.com/2017/01/03/z270-motherboard-guide/5/
Menthol
Level 14
61558
jab383
Thanks Arne and Menthol. Now I'm beginning to catch up.
upsnef
Level 11
the extreme have 2 slot M.2 , one is under the active heatsink attached to waterblock and the other is under the southbridge chipset cover
