Kaby Lake @ 5.0GHZ and above, Yes it does
Menthol
Level 14
It has been reported that the new Kaby Lake 7700K CPU's can overclock to 5.0 on 1.35 volts
Without giving to much information my retail sample 7700K can run RealBench 2.44 at 5.0 at 1.35 volts easy, can validate @ 5.1 1.35 volts, locks up at 5.2
Not sure if I have a good chip or not but pretty excited to play with this new chip
Haven't delidded it yet like all my Skylake CPU's are and the temps it hit running RealBench @ 5.0 with a Corsair h115i I may not, mid 70"s on open bench table
Supposedly the IMC has been improved and runs memory at high speeds, I will be checking this out soon, this is on a an ASUS Z-170 board
61402
69 REPLIES 69
Heini
Level 11
Obvisiously to early to determine but any what this means to the 170 folks hoping to upgrade?
JustinThyme
I may give one of these a try soon when they are more readily available, hate paying a scalpers price.
What it means to me would be lower Vcore to get to 5GHz. I dont have heat issues now with my custom loop. I did have horrendous heat issue with the first solution I tried, the corsair h115i. Went from spiking to 90C at 4.9 GHz and 1.440 Vcore to passing 5 Ghz at 1.495 Vcore with max temp of 60 since the Delid and going to a custom loop. It also took a lot of tweaking to pass the 5Ghz mark and it was on a 48 multi with a higher BCLCK a little past 104.
samual
Level 11
Won't be picking mine up until Febuary (Christmas bills). Plan on Maximus VIX Extreme , 1080 Ti and 960 evo
x99-pro/3.1 | i7-5820k | 16gb gskils 3000 | Nvidia gtx 980 ti | 512gb SM950 Pro | Predator 360 AIO | ASUS PA248Q | Seasonic Platnium 1000w
Looks Like I was wrong in a big way, WOW
61527
Arne_Saknussemm
Level 40
Menthol
Level 14
samual I haven't seen anything on a Z-270 Extreme board, my guess is it will be like Z-97 and Formula will be top board this GEN
Arne, Thanks for the compliment but what about the overclock 🙂
Arne_Saknussemm
Level 40
:D...yeah, that too...if stuff is hitting 5.0 then you can call it overclocking...
samual
Level 11
Bummer if there is no extreme board. I guess I'll go with the formula but i am not a fan of the armor.
NemesisChild
Level 12
Nice OC menthol! Have you run any benchmarks versus the 6700K?
Damn, I was going to pass up on KL, but 5.0 is very tempting.
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
