06-25-2024 09:05 PM - edited 06-26-2024 08:07 PM
I have recently purchased 15 inch touch screen monitor from BaoBao Technology and Now want to purchase ASUS products. I'm totally new in this field, my budget is $1200 please recommend any good device. Thankx
Solved! Go to Solution.
06-25-2024 10:00 PM
Hi @Sarah6ytyy,
Any ideas about what you're likely to be doing/playing? Are you planning to be on the move a lot and prefer to be more portable?
Have you considered the ROG Ally and something like the Falchion RX and Keris II Ace?
06-25-2024 10:00 PM
Hi @Sarah6ytyy,
