Hi jon_mann
Welcome to the ROG forum.
2400MHz should run pretty easy but since it's giving you trouble try setting your ram manually.
Hit F5 to reset to defaults.
1) On the Extreme Tweaker tab set the AI overclock Tuner to Manual
2) Scroll down to Dram frequency and select 2400MHz.
3) Scroll down to Dram voltage and enter in 1.20v
4) Scroll down to CPU Sytem Agent voltage and enter in 1.10v
5) Scroll down to CPU VCCIO voltage and enter in 1.10v
6) Go to Dram Timing Control and and the very top select Maximus Tweak Mode 1, under primary timings set:
14
16
31
2N
F10 and Enter
How does she go ?
