Is the TUF GT302 case fully BTF compatible with MB TUF B760 BTF WiFi ?
wernst
I would like to build a BTF capable PC. The MB is a TUF Gaming B760M BTF WiFi plus the TUF Gaming GT302 ARGB as PC case, which is supposed to be BTF-capable. Is it? The Asus BTF product overview page only lists the A21 case as compatible with the MB B760M BTF. My question: Is the MB B760M BTF WiFi truly and fully compatible with the GT302 case ? (the new GPU high power slot is excluded and not needed here)
1 ACCEPTED SOLUTION
Accepted Solutions
AlexWhales
Building a BTF (Back To Front) capable PC with the TUF Gaming B760M BTF WiFi motherboard and the TUF Gaming GT302 ARGB case is an exciting project! BTF is a unique design that routes most of the cables behind the motherboard, which can lead to a cleaner and more efficient build.
However, as you've noticed, the official Asus BTF product overview lists the A21 case as compatible with the B760M BTF motherboard, which raises a question about the GT302 case.
Compatibility Considerations:
1. Cable Management and Routing: The key feature of BTF technology is its cable management system, which requires specific routing paths and openings in the case. While the GT302 is a TUF Gaming case and might offer some level of compatibility, it might not fully support the unique BTF layout. The A21 case is explicitly designed for this purpose, ensuring all cables fit neatly behind the motherboard.
2. Connector Alignment: Another critical aspect is the alignment of connectors and ports. The A21 case will have the necessary cutouts and pathways specifically designed for BTF motherboards like the B760M. The GT302 might lack these precise alignments, which could make installation more challenging or less clean.
3. Future Proofing:  While the GT302 case is a robust choice for many builds, it might not fully leverage the benefits of the BTF motherboard design. If the clean aesthetic and cable management are priorities, sticking with officially supported cases like the A21 might be the better option.
While the GT302 case may physically accommodate the B760M BTF WiFi motherboard, it may not fully support the BTF features, leading to potential challenges in achieving the clean build that BTF is designed for. If BTF capability is your primary goal, considering the A21 case might be a better option to ensure full compatibility and ease of assembly. However, if you're willing to experiment and don't mind potentially doing some custom work, the GT302 could still be an option.
AlexWhales
javiercarpenter
AlexWhales hit the nail on the head. While the GT302 might fit, official BTF support goes to the A21 case. A21 ensures smooth cable routing and connector alignment for a hassle-free BTF build.
