Hi everybody. Thanks for all the help so far. I've been slowly putting my first build together after work each night, and I'm almost through. The last thing I need to do is wire the graphics card.
I've got the card installed and screwed in, but I have three basic questions:
1. the card has a 6 pin PCL-E and an 8 pin. Which one should I use to connect to the PS? I have the 6 pin + 2 PCL-E. Does it matter?
2. the card itself has no display port but just a plastic grill on the mounting side. I presume this means I just connect the monitor via the motherboard's HDMI port. Is this correct?
3. Finally, the card has a protective rubber fin over a front connection, the purpose of which I am unsure of, should I leave this protective fin on or take it off?
Sorry for all the basic rookie questions. I just don't want to fry anything, and there's a bit of a dearth of good wiring videos on Youtube. Thanks.
Here are some pictures:
