[INDEX] All My Drivers/Firmware/Software Threads
MoKiChU
Level 40
Hi everyone,
I created this thread in order to simply index all the threads that I offer :
Here is the best way to follow my threads (you must be registered and logged in) :
1) Open in a new tab all the interesting and useful threads for your products from my index thread.
2) Subscribe to all open threads in a new tab via Options > Subscribe (top right of the first post of the thread).
3) Keep you informed of all subscribed thread activity via your Subscriptions : https://rog-forum.asus.com/t5/user/myprofilepage/tab/user-subscriptions.
DRIVERS
[DRIVERS] AMD Chipset/RAID (3xx/4xx/5xx/6xx/TRX40)
[DRIVERS] AMD Chipset/RAID (Legacy 6xx/7xx/8xx/9xx)
[DRIVERS] Intel Chipset/MEI/VMD (6xx/7xx)
[DRIVERS] Intel Chipset/MEI/SATA (1xx/2xx/3xx/4xx/5xx)
[DRIVERS] Intel Chipset/MEI/SATA/VROC (X299)
[DRIVERS] Intel Chipset/MEI/SATA (6x/7x/8x/9x)
[DRIVERS] Intel Serial IO (4xx/5xx/6xx/7xx)
[DRIVERS] Intel DTT/GNA (5xx/6xx/7xx)
[DRIVERS] Intel Thunderbolt
[DRIVERS] ASMedia SATA
[DRIVERS] Marvell SATA
[DRIVERS] JMicron SATA
[DRIVERS] Intel Ethernet/WiFi/Bluetooth
[DRIVERS] AMD|MediaTek WiFi/Bluetooth
[DRIVERS] Marvell/Aquantia Ethernet
[DRIVERS] Realtek Ethernet/WiFi/Bluetooth
[DRIVERS] Qualcomm Ethernet/WiFi/Bluetooth
[DRIVERS] Broadcom WiFi/Bluetooth
[DRIVERS] Realtek USB Audio (AMD 5xx/6xx/TRX40 & Intel 5xx/6xx/7xx)
[DRIVERS] Realtek Audio (AMD 3xx/4xx/5xx/6xx & Intel 2xx/3xx/4xx/5xx/6xx/7xx)
[DRIVERS] Realtek Audio (AMD Legacy 6xx/7xx/8xx/9xx & Intel 6x/7x/8x/9x/1xx)
[DRIVERS] VIA Audio (AMD Legacy 6xx/7xx & Intel 6x/7x)
[DRIVERS] AMD iGPU (CPU)
[DRIVERS] Intel iGPU (11xxx/12xxx/13xxx/14xxx CPU)
[DRIVERS] Intel iGPU (6xxx/7xxx/8xxx/9xxx/10xxx CPU)
[DRIVERS] Intel iGPU (2xxx/3xxx/4xxx/5xxx CPU)
[DRIVERS] NVIDIA GeForce GPU (9xx/10xx/16xx/20xx/30xx/40xx)
[DRIVERS] NVIDIA GeForce GPU (6xx/7xx)
[DRIVERS] NVIDIA GeForce GPU (4xx/5xx)
[DRIVERS] NVIDIA GeForce GPU (1xx/2xx/3xx)
FIRMWARE
[FIRMWARE] Intel ME (H610/B660/H670/Z690/B760/H770/Z790)
[FIRMWARE] Intel ME (H510/B560/H570/Z590)
[FIRMWARE] Intel ME (H470/Z490)
[FIRMWARE] Intel ME (H410/B460)
[FIRMWARE] Intel ME (H310/B360/H370/Z390)
[FIRMWARE] Intel ME (H110/B150/H170/Z170/B250/H270/Z270/B365/Z370)
[FIRMWARE] Intel ME (X299)
[FIRMWARE] Intel ME (H81/B85/H87/Z87/H97/Z97/X99)
[FIRMWARE] Intel ME (H61/B65/H67/P67/Z68/B75/Z75/H77/Z77/X79)
[TOOL] Intel ME Security Check (1xx/2xx/3xx/4xx/5xx/6xx/7xx)
[TOOL] Intel ME Security Check (6x/7x/8x/9x)
SOFTWARE
[SOFTWARE] CPU-Z/GPU-Z ROG/TUF/PRIME Edition
[SOFTWARE] SignalRGB
[INFORMATION] Windows 11 : Get Ready
62 REPLIES 62
Thanks so much. You just made my day!
last question, do I install in that exact order?
Correct, the order to follow is the one listed in this index thread (or in my answer), from top to bottom.
@MoKiChU wrote:
You need these drivers/firmware for your ASUS ROG Strix Z790-F Gaming WiFi motherboard (you don't need Intel VMD, IPF-DTT, GNA & iGPU Drivers if you disabled/don't enabled them in your BIOS) :
Intel Chipset Drivers
Intel MEI Drivers (Drivers Only)
Intel VMD Drivers (Drivers Only)
[DRIVERS] Intel Serial IO (3xx/4xx/5xx/6xx/7xx)
- Intel Serial IO Drivers (Drivers Only) :
Drivers - 6xx/7xx
[DRIVERS] Intel IPF-DTT/GNA (5xx/6xx/7xx)
Intel IPF-DTT Drivers (Drivers Only)
Intel GNA Drivers (Drivers Only)
- Intel Ethernet Drivers (Drivers Only) :
Drivers - I225/I226
- Intel WiFi Drivers (Drivers Only) :
Drivers - 9xxx/AXxxx/BExxx
- Intel Bluetooth Drivers (Drivers Only) :
Drivers - AXxx1/BExxx
You have an ASUS ROG SS3|DTS Sound Unbound motherboard with ALC408x codec, so :
You need Realtek USB Audio Drivers (UAD - ASUS ROG SS-DTS) from the first post of this thread.
Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
Hi there!
Quick question for confirmation: for the ASUS ROG STRIX Z590-I GAMING WIFI it's the same list of drivers, except for the Intel VMD Drivers and the Intel IPF-DTT Drivers that are not needed, and of course the Intel ME Firmware that I should install the one from the other thread (Z590), right?
Btw...if I try to install the Intel iGPU drivers, it tells me that I don't have any supported hardware (No supported devices by the driver).
Unlike AMD iGPUs which remain enabled in the presence of a graphics card (the iGPU must be disabled manually in your BIOS), Intel iGPUs are automatically disabled in the presence of a graphics card (if necessary, the iGPU must be enabled manually in your BIOS).
You need these drivers/firmware for your ASUS ROG Strix Z590-I Gaming WiFi motherboard (you don't need GNA & iGPU Drivers if you disabled/don't enabled them in your BIOS) :
- Intel SATA AHCI-RAID Drivers (Drivers Only) :
Drivers - 4xx/5xx
Drivers - 5xx
Drivers - I225/I226
You have an ASUS ROG SS3|DTS Sound Unbound motherboard with ALC40xx codec, so :
Thank you very much for confirmation.
I have GNA and iGPU both enabled in BIOS, but only GNA can be successfully installed, while the iGPU drivers are not as I guess I have my NVidia GPU installed and working as the primary GPU.
I'll try removing my NVidia GPU and connect my monitor using the motherboard onboard HDMI cable so to install the iGPU drivers.
SaltyMango
Hi, which drivers do I need? I have the b550-f rog strix and Ryzen 7 5700x.
You need these drivers for your ASUS ROG Strix B550-F Gaming motherboard :
AMD Chipset Drivers
Drivers - I225/I226
You have an ASUS ROG SS3|DTS Sound Unbound motherboard, so :
You need Realtek Audio Drivers (UAD - ASUS ROG SS3-DTS) from the first post of the thread.
InfinityHunterZ
Hey can you tell me which drivers i need? I have an Asus Rog strix Z790-H Gaming Wifi and an i-5 13600k. Appreciate your work!
You need these drivers/firmware for your ASUS ROG Strix Z790-H Gaming WiFi motherboard (you don't need Intel VMD, DTT, GNA & iGPU Drivers if you disabled/don't enabled them in your BIOS) :
Drivers - 6xx/7xx
Intel DTT Drivers (Drivers Only)
Drivers - I225/I226
You need Realtek Audio Drivers (UAD - ASUS ROG SS3-DTS) from the first post of this thread.
Levonor
Does these drivers works on Asus TUF F17 Gaming Laptop?.... I'm trying to fix a USB 3 speed problem (works like a USB 2.0) and some forum post bring me here. Sorry for my english xDD
