[INDEX] All My Drivers/Firmware/Software Threads
MoKiChU
Level 40
Hi everyone,
I created this thread in order to simply index all the threads that I offer :
Here is the best way to follow my threads (you must be registered and logged in) :
1) Open in a new tab all the interesting and useful threads for your products from my index thread.
2) Subscribe to all open threads in a new tab via Options > Subscribe (top right of the thread).
3) Keep you informed of all subscribed thread activity via your Notification feed : https://rog-forum.asus.com/t5/notificationfeed/page.
DRIVERS
[DRIVERS] AMD Chipset/RAID (3xx/4xx/5xx/6xx/8xx)
[DRIVERS] AMD Chipset/RAID (Legacy 6xx/7xx/8xx/9xx)
[DRIVERS] Intel Chipset/MEI/VMD/Serial IO/GNA/DTT/HID/PMT (6xx/7xx/8xx)
[DRIVERS] Intel Chipset/MEI/SATA/Serial IO/GNA (1xx/2xx/3xx/4xx/5xx)
[DRIVERS] Intel Chipset/MEI/SATA/VROC (X299)
[DRIVERS] Intel Chipset/MEI/SATA (6x/7x/8x/9x)
[DRIVERS] ASMedia USB4
[DRIVERS] Intel Thunderbolt
[DRIVERS] ASMedia SATA
[DRIVERS] Marvell SATA
[DRIVERS] JMicron SATA
[DRIVERS] Intel Ethernet/WiFi/Bluetooth
[DRIVERS] AMD|MediaTek WiFi/Bluetooth
[DRIVERS] Marvell/Aquantia Ethernet
[DRIVERS] Realtek Ethernet/WiFi/Bluetooth
[DRIVERS] Qualcomm Ethernet/WiFi/Bluetooth
[DRIVERS] Broadcom WiFi/Bluetooth
[DRIVERS] Intel SST Audio (8xx)
[DRIVERS] Realtek USB Audio (AMD 5xx/6xx/8xx & Intel 5xx/6xx/7xx/8xx)
[DRIVERS] Realtek Audio (AMD 3xx/4xx/5xx/6xx/8xx & Intel 2xx/3xx/4xx/5xx/6xx/7xx/8xx)
[DRIVERS] Realtek Audio (AMD Legacy 6xx/7xx/8xx/9xx & Intel 6x/7x/8x/9x/1xx)
[DRIVERS] VIA Audio (AMD Legacy 6xx/7xx & Intel 6x/7x)
[DRIVERS] AMD NPU (Ryzen 8xxx APU)
[DRIVERS] AMD iGPU/GPU (Ryzen CPU/APU & Radeon 5x00/6x00/7x00/90xx GPU)
[DRIVERS] Intel NPU (2xx CPU)
[DRIVERS] Intel iGPU/GPU (11xxx/12xxx/13xxx/14xxx/2xx CPU & Arc Axxx/Bxxx GPU)
[DRIVERS] Intel iGPU (6xxx/7xxx/8xxx/9xxx/10xxx CPU)
[DRIVERS] Intel iGPU (2xxx/3xxx/4xxx/5xxx CPU)
[DRIVERS] NVIDIA GeForce GPU (9xx/10xx/16xx/20xx/30xx/40xx/50xx)
[DRIVERS] NVIDIA GeForce GPU (6xx/7xx)
[DRIVERS] NVIDIA GeForce GPU (4xx/5xx)
[DRIVERS] NVIDIA GeForce GPU (1xx/2xx/3xx)
FIRMWARE
[FIRMWARE] Intel ME (H810/B860/Z890)
[FIRMWARE] Intel ME (H610/B660/H670/Z690/B760/H770/Z790)
[FIRMWARE] Intel ME (H510/B560/H570/Z590)
[FIRMWARE] Intel ME (H470/Z490)
[FIRMWARE] Intel ME (H410/B460)
[FIRMWARE] Intel ME (H310/B360/H370/Z390)
[FIRMWARE] Intel ME (H110/B150/H170/Z170/B250/H270/Z270/H310/B365/Z370)
[FIRMWARE] Intel ME (X299)
[FIRMWARE] Intel ME (H81/B85/H87/Z87/H97/Z97/X99)
[FIRMWARE] Intel ME (H61/B65/H67/P67/Z68/B75/Z75/H77/Z77/X79)
[TOOL] Intel ME Security Check (1xx/2xx/3xx/4xx/5xx/6xx/7xx/8xx)
[TOOL] Intel ME Security Check (6x/7x/8x/9x)
SOFTWARE
[SOFTWARE] CPU-Z/GPU-Z ROG Edition
[INFORMATION] Windows 11 : Get Ready
158 REPLIES 158
Hey man, you seem very knowledgeable. Please help me, what I should install/do to get hd audio loudness equalization option or effect with z690-f mobo?
Please, this thread is an index thread, don't ask support here next time. Since you have an ASUS ROG SS3|DTS Sound Unbound motherboard, the loudness equalization is done via the SS3 app (the loudness equalization effect is called Smart Volume in SS3 effects settings).
You need these drivers/firmware for your ASUS ROG Strix Z690-F Gaming WiFi motherboard (you don't need Intel GNA Drivers & Intel iGPU Drivers if you don't enabled them in your BIOS) :
[DRIVERS] Intel Chipset/MEI/VMD (6xx/7xx)
Intel Chipset Drivers
Intel MEI Drivers (Drivers Only)
Intel VMD Drivers (Drivers Only)
[DRIVERS] Intel Serial IO (4xx/5xx/6xx/7xx)
- Intel Serial IO Drivers (Drivers Only) :
Drivers - 6xx/7xx
[DRIVERS] Intel GNA (5xx/6xx/7xx)
- Intel Ethernet Drivers (Drivers Only) :
Drivers - I225/I226
- Intel WiFi Drivers (Drivers Only) :
Drivers - 9xxx/AXxxx
- Intel Bluetooth Drivers (Drivers Only) :
[DRIVERS] Realtek USB Audio (AMD 5xx/6xx/TRX40 & Intel 5xx/6xx/7xx)
You have an ASUS ROG SS3|DTS Sound Unbound motherboard with ALC408x codec, so :
You need Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) from the first post of this thread.
Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
[DRIVERS] Intel iGPU (11xxx/12xxx/13xxx/14xxx CPU)
RandyEastman
thank you sir
Thilxn1248
USB\VID_0BDA&PID_8771 which driver should i take
My motherboard is z370f strix
intel i58600k
msi 3060 gaming x 12gb
Your motherboard (I have the same motherboard) don't have Bluetooth controller built-in and the HWID USB\VID_0BDA&PID_8771 corresponds to a Realtek Bluetooth device.
So if you added BT via BT USB adapter, please refer to your product support page to download/use the appropriate drivers for your product.
@ Everyone
: I remind to everyone that my field is the ASUS motherboards (DIY PC) and that all my threads are AIMed for ASUS motherboards only and not AIMed for ASUS notebooks/laptops/AiO or any ASUS devices like ASUS WiFi/BT USB adapters. So if you don't have ASUS motherboards my threads are not for you, please refer to your product support page to download/use the appropriate drivers for your product.
nbobich79
Thanks for all your Hard Work @MoKiChU . Keep up the good work these drivers are very helpful ASUS never keeps anything up to date on the main website!
Thilxn1248
my board is z370f and i5 8600k cpu ping me all drivers i need please
You need these drivers/firmware for your ASUS ROG Strix Z370-F Gaming motherboard and your NVIDIA GeForce RTX 3060 GPU :
[DRIVERS] Intel Chipset/MEI/SATA (1xx/2xx/3xx/4xx/5xx)
- Intel SATA AHCI-RAID Drivers (Drivers Only) :
Drivers - 2xx/3xx
Drivers - I217/I218/I219
[DRIVERS] Realtek Audio (AMD 3xx/4xx/5xx/6xx & Intel 2xx/3xx/4xx/5xx/6xx/7xx)
You have an ASUS ROG SS3 motherboard, so :
You need Realtek Audio Drivers (UAD - ASUS ROG SS3) from the first post of the thread.
[FIRMWARE] Intel ME (H110/B150/H170/Z170/B250/H270/Z270/B365/Z370)
[DRIVERS] NVIDIA GeForce GPU (9xx/10xx/16xx/20xx/30xx/40xx)
