05-31-2020 05:23 AM - last edited a week ago
Hi everyone,
I created this thread in order to simply index all the threads that I offer :
Here is the best way to follow my threads (you must be registered and logged in) :
1) Open in a new tab all the interesting and useful threads for your products from my index thread.
2) Subscribe to all open threads in a new tab via Options > Subscribe (top right of the thread).
3) Keep you informed of all subscribed thread activity via your Notification feed : https://rog-forum.asus.com/t5/notificationfeed/page.
DRIVERS
[DRIVERS] AMD Chipset/RAID (3xx/4xx/5xx/6xx/8xx)
[DRIVERS] AMD Chipset/RAID (Legacy 6xx/7xx/8xx/9xx)
[DRIVERS] Intel Chipset/MEI/VMD/Serial IO/GNA/DTT/HID/PMT (6xx/7xx/8xx)
[DRIVERS] Intel Chipset/MEI/SATA/Serial IO/GNA (1xx/2xx/3xx/4xx/5xx)
[DRIVERS] Intel Chipset/MEI/SATA/VROC (X299)
[DRIVERS] Intel Chipset/MEI/SATA (6x/7x/8x/9x)
[DRIVERS] ASMedia USB4
[DRIVERS] Intel Thunderbolt
[DRIVERS] ASMedia SATA
[DRIVERS] Marvell SATA
[DRIVERS] JMicron SATA
[DRIVERS] Intel Ethernet/WiFi/Bluetooth
[DRIVERS] AMD|MediaTek WiFi/Bluetooth
[DRIVERS] Marvell/Aquantia Ethernet
[DRIVERS] Realtek Ethernet/WiFi/Bluetooth
[DRIVERS] Qualcomm Ethernet/WiFi/Bluetooth
[DRIVERS] Broadcom WiFi/Bluetooth
[DRIVERS] Intel SST Audio (8xx)
[DRIVERS] Realtek USB Audio (AMD 5xx/6xx/8xx & Intel 5xx/6xx/7xx/8xx)
[DRIVERS] Realtek Audio (AMD 3xx/4xx/5xx/6xx/8xx & Intel 2xx/3xx/4xx/5xx/6xx/7xx/8xx)
[DRIVERS] Realtek Audio (AMD Legacy 6xx/7xx/8xx/9xx & Intel 6x/7x/8x/9x/1xx)
[DRIVERS] VIA Audio (AMD Legacy 6xx/7xx & Intel 6x/7x)
[DRIVERS] AMD NPU (Ryzen 8xxx/9xxx APU)
[DRIVERS] AMD iGPU/GPU (Ryzen CPU/APU & Radeon 5x00/6x00/7x00/90xx GPU)
[DRIVERS] Intel NPU (2xx CPU)
[DRIVERS] Intel iGPU/GPU (2xx CPU & Arc Axxx/Bxxx GPU)
[DRIVERS] Intel iGPU (11xxx/12xxx/13xxx/14xxx CPU)
[DRIVERS] Intel iGPU (6xxx/7xxx/8xxx/9xxx/10xxx CPU)
[DRIVERS] Intel iGPU (2xxx/3xxx/4xxx/5xxx CPU)
[DRIVERS] NVIDIA GeForce GPU (16xx/20xx/30xx/40xx/50xx)
[DRIVERS] NVIDIA GeForce GPU (9xx/10xx)
[DRIVERS] NVIDIA GeForce GPU (6xx/7xx)
[DRIVERS] NVIDIA GeForce GPU (4xx/5xx)
[DRIVERS] NVIDIA GeForce GPU (1xx/2xx/3xx)
FIRMWARE
[FIRMWARE] Intel ME (H810/B860/Z890)
[FIRMWARE] Intel ME (H610/B660/H670/Z690/B760/H770/Z790)
[FIRMWARE] Intel ME (H510/B560/H570/Z590)
[FIRMWARE] Intel ME (H470/Z490)
[FIRMWARE] Intel ME (H410/B460)
[FIRMWARE] Intel ME (H310/B360/H370/Z390)
[FIRMWARE] Intel ME (H110/B150/H170/Z170/B250/H270/Z270/H310/B365/Z370)
[FIRMWARE] Intel ME (X299)
[FIRMWARE] Intel ME (H81/B85/H87/Z87/H97/Z97/X99)
[FIRMWARE] Intel ME (H61/B65/H67/P67/Z68/B75/Z75/H77/Z77/X79)
[TOOL] Intel ME Security Check (1xx/2xx/3xx/4xx/5xx/6xx/7xx/8xx)
[TOOL] Intel ME Security Check (6x/7x/8x/9x)
SOFTWARE
[SOFTWARE] CPU-Z/GPU-Z ROG/TUF/PRIME/ProArt Edition
[INFORMATION] Windows 11 : Get Ready
[INFORMATION] Secure Boot : Windows UEFI CA 2023 Update
10-06-2024 08:50 AM
Hi, I downloaded everything you recommend - just in case. Again; thank you very much, and, stay healthy! Guys like you make a difference!
10-24-2024 04:33 AM
@Partysus wrote:
Hey MoKiChU.
Can you please tell me which drivers i need to Z170 PRO GAMING/AURA
You need these drivers/firmware for your ASUS Z170 PRO GAMING/AURA motherboard (you don't need Intel iGPU Drivers if you disabled/don't enabled it in your BIOS) :
[DRIVERS] Intel Chipset/MEI/SATA (1xx/2xx/3xx/4xx/5xx)
- Intel Chipset Drivers
- Intel MEI Drivers (Drivers Only)
- Intel SATA AHCI-RAID Drivers (Drivers Only) :
- Intel Ethernet Drivers (Drivers Only) :
You have an ASUS SS2 motherboard, so :
You need Realtek High Definition Audio Drivers (HDA - ASUS ROG SSx) from the first post of the thread.
Follow scrupulously your CLEANUP process then your INSTALL process.
@Partysus wrote:
And ROG STRIX Z370-F GAMING
Thanks for all
You need these drivers/firmware for your ASUS ROG Strix Z370-F Gaming motherboard (you don't need Intel iGPU Drivers if you disabled/don't enabled it in your BIOS) :
You have an ASUS ROG SS3 motherboard, so :
You need Realtek Audio Drivers (UAD - ASUS ROG SS3-DTS) from the first post of the thread.
Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
10-24-2024 04:53 AM
Thank you so much 👍
10-29-2024 10:44 PM
You have an ASUS ROG SS3|DTS Sound Unbound motherboard, so :
You need Realtek Audio Drivers (UAD - ASUS ROG SS3-DTS) from the first post of this thread : [DRIVERS] Realtek Audio (AMD 3xx/4xx/5xx/6xx/8xx & Intel 2xx/3xx/4xx/5xx/6xx/7xx/8xx).
10-30-2024 12:10 AM
Thank you so much!
Your cleanup process was particularly effective at fixing at least 3 problems I was having in Windows 11, which I had no idea were caused by the Realtek audio driver package from the Asus motherboard support page:
1) The Windows startup sound would never play.
2) The calculator was very slow to open.
3) The Start Menu Power flyout was very slow.
They are all fixed now, and Windows installed a basic Microsoft HD audio driver which seems to work fine, so I don't think I'll even install the Realtek driver and Sonic apps.
11-07-2024 02:39 PM
Hi, i also encountered the same problem as you ... i solved it by uninstalling only SONIC RADAR
10-31-2024 05:01 PM
Hi
Could you please give me the drivers for my Ryzen 7 7800X3D, ROG Strix X670E-E and RTX 4090 build
Thank you 🙂
11-01-2024 01:09 AM
You need these drivers for your ASUS ROG Strix X670E-E Gaming WiFi motherboard (you don't need AMD iGPU Drivers if you disabled/don't enabled it in your BIOS) :
- AMD Chipset Drivers
- Intel WiFi Drivers (Drivers Only) :
- Intel Bluetooth Drivers (Drivers Only) :
You have an ASUS ROG SS3|DTS Sound Unbound motherboard with ALC40xx codec, so :
You need Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) from the first post of the thread.
Also, you need these drivers for your graphics card :
