Hi there so here's the situation: i recently completed my build with my motherboard asus z370 strix e and I can't find how to set up the RGB in the Bios. can somebody please tell me how to set it up?
I don't know about the Strix but if there is control in the bios it is under Onboard Devices and allows turning on or off only, you need to install ASUS Aura to control RGB
