Pixxie payne wrote:
not sure wether to trust APU's tbh 😕 they seam a bit over rated in my eyes, ur best waiting for either the 28nm cpu's or get a bulldozer cpu
well your right they are but if you take advantage from the new egg interview with JJ from asus you make a sweet rig with it
i have to say testing the new system out was great took me a while to find out how to crossfire my xfx 6670 with the 6550D
playing games is a snap bad thing is i am not using full power meaning i am still under 32bit using one 4gig of ram witch registers at 2.98 gb i bought another set of 8gb just in case i damage the one i am using (right?) and since i can up it to 64gbs later 16gb each slot with updates to the bios later on its not a prob
if i take up all the use this mb and apu has to offer with the good amount of ram i would have no problem playing games or watching movies HD sound and graphics are killer using the i inc 28 in monitor i got
but i am waiting on a 16 core amd chip in witch they scrapped cause 8 core is good enough for now (so they say)
would like to wait when the 8 core gets cheaper 8150 is 269 once i see it at 200 or less i am in
but dont lose your trust on dual graphic its going to out source sli and crossfire
i rather see a 8 -16 core with integrated graphic then to have 6 gpus to run a game
here is an example of a rig if you go with out Amd APU
ASUS M5A88-M AMD 880G AM3+ Motherboard has hybrid supports 8 core if it didnt have 4250 or OC DDR3 2000MHz
or DDR3 1866MHz (OC) i would say this MB is great but if it was capable of holding a 7000 hd series integrated chip ddr3 1866 and up holding 64gb total ram you would be golden for 4yr liquid cool the pc later on and OC the heck out of it hybrid or apu will kill the sli and crossfire to much waste of space getting 6 GPU taking up electric just to play a mmo or fps
not a hater just old school i remember being ok playing Oregon trails on the commador 64 and playing rouge spear on a 32mb geforce now its like gigbites and 6 would make you king
but then again you have to see and try for your self
thank you all for all the help and advice
