* updated 2-21-12*
well i ended up buying all the parts you see here from tiger direct
i was a bit upset that TD didnt want to do a price match over newegg cause
it was "way below our standard price" so said the TD REP so if any one wants to take advantage i left the
new egg links there
i went with TD cause i wanted to buy the XFX video card and wanted UPS to ship all my items in one box
instead of having two companies send me two boxes and a longer wait to get everything
shipping was a mess due to presidents day made my order on the 19th with two day shipping but end up getting my items tomorrow the 22nd witch sucked two times as they shipped it on the 21st at the crack of dawn
ASUS F1A75-V PRO FM1 AMD A75
http://www.newegg.com/Product/Produc...82E16813131765CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866
http://www.newegg.com/Product/Produc...82E16820233142AMD A8-3870K Unlocked Llano 3.0GHz Socket FM1 100W Quad-Core Desktop APU with DirectX 11 Graphic AMD Radeon HD 6550D
http://www.newegg.com/Product/Produc...82E16819106001XFX HD-667X-ZWF4 Radeon HD 6670 Video Card - 1GB, DDR5
http://www.tigerdirect.com/applicati...&Sku=P450-6676now i have a zalman 500w power supply 80plus bronze ( would this power supply work with my set up?)
2tb WD hard drive
now i have windows xp 32 bit witch i think might be a problem if i am not mistaken
so would i have to go to a windows 7 64Bit if i take on the 8 gigs of ram correct?
would like to know so i can start looking for a cheap place to get the retail version of windows 7
cause not sure what would be the difference to get the OEM with RETAIL
i take that its just that i wont get full support if i go with the OEM correct?
but everything else is legit full working right?
and if i pick OEM i would have to go with 64 bit right ?
THANK YOU all for viewing and would appreciate if i got a reply or if you guys got questions feel free to ask or post
