I think i made a mistake
Amphieuss
Hi all ,
Ok.. i think i made a mistake with building my PC.
Here come my parts :
MB: ASUS ROG STRIX X670E-E GAMING WIFI, socket AM5
GPU: INNO3D GeForce RTX 4080 X3
AIO Cooler : NZXT Kraken Elite 360 RGB Black
CPU: AMD Ryzen 7 7800X3D
RAM: Corsair DDR5 Vengeance RGB 2x16GB 6000 (CMH32GX5M2D6000C36)
SSD: Samsung 980 Pro m.2 SSD
PSU: Gigabyte GP-UD1000GM PG5 V2.0
So seeing all the problems with the 7800x3d Cpu , makes my heart almost explode.
Next to that i think i have the wrong RAM chosen, its not on the QVL-List and its not EXPO but XMP.. Didnt realise this untill after i put the order in.
Im desperately trying to cancel the order for the RAM , but i think it wont be possible.
So now what ? is this going to be a problem , The RAM also uses 1.35v .. as i understood the new BIOS is limiting the V to 1.30v
Any help or advice would be highly appreciated.
Amphieuss
paco7320
I've got the new bios and my ram is set at 1.38v because it won't run at 6000 at 1.35v. The 1.3v restriction is to the cpu because they were getting overvolted. My ram is G. Skill x flare 5 6000
