09-26-2022
09:31 AM
- last edited on
03-06-2024
10:13 PM
by
ROGBot
09-26-2022 11:21 PM
09-27-2022 04:23 AM
Silent Scone@ROG wrote:
Hello,
Use the latest drivers either noted by the board vendor or manufacturer.
Only update the UEFI if experiencing compatibility or stability issues.
If experience any specific problems, specify so others can help.
09-27-2022 02:35 PM
09-28-2022 02:14 PM
Murph_9000 wrote:
You need BIOS 0801 for AMD AGESA 1.2.0.7, which fixes a performance problem with Windows 11 & TPM. I've not looked through all of the previous BIOS versions, but there may also be security fixes for CPU vulnerabilities. BIOS used to be something that should be left alone if everything is working well, but it can leave your system vulnerable to attack with modern CPU security problems.
I've been running 0801 for months, it seems fairly solid.
09-28-2022 02:39 PM
09-28-2022 11:20 PM
AQUASTEVAE wrote:
While I appreciate the reply, that doesn't really answer my question about the latest bios. IF the latest bios is stable and working well, it's important to have those features to allow me to gain the full power and feature set of this board. BUT, if the latest bios is faulty, and those who have already loaded it are experiencing more problems than it's worth, then I prefer to stay on the earlier bios. But getting that information from the community is what I came here for.
10-05-2022 03:02 PM
What features are you even referring to. I see now you've run into difficulties with stability after updating, which was why i gave the answer I did. Unless there's some compatibility you're desperate for.
In terms of OC, there's no guarantees later ucode will net you any more overclocking range or performance. You'd be better off tuning the system and then deciding, rather than making the decision based on this. If overclocking, compromise is the word of the day. I've often stayed on builds that work best for my CPU and memory.
