04-28-2012
04:05 AM
- last edited on
03-06-2024
08:27 PM
by
ROGBot
05-10-2012 04:29 PM
05-10-2012 05:18 PM
05-10-2012 05:19 PM
05-04-2012 01:38 PM
05-10-2012 04:53 PM
Rassal wrote:
So you said anything that goes slow is ok (like downloading big 1gb files) but doing many updates at the same time on a faster way give you all kind of problems...
I would start thinking you might have a bad or corrupted disk controller driver... or badly configured one. Could you give us more details on how you are setup with your HDD/SSD? Are you using AHCI or IDE or RAID? Which version of bios you have, which controller on your motherboard you are using and of course, which drivers you are also using.
I don't want to fall for the fastest and easiest way here, but many small files or updates means lot of I/O on disk and if you are having problem it seems to be related to I/O and i mostly never saw problems related to the speed of the ISP that would make you fail to install a driver or a piece of software.
I have had in the past many customers come to me with problems like yours related to bad raid drivers, badly configured write cache, or plain incompatible driver version with the onboard controller firmware version.
Please enlighten us on the way you started your windows installation, because, out of the box, windows 7 got a lot of drivers that should enable you to install windows correctly. WIth x79 chipset, you have to specify the drivers, and it might be your problem... bad disk controller drivers that could lead to the total instability you are experiencing.
05-10-2012 06:10 PM
05-10-2012 07:30 PM
chrsplmr wrote:
Brother .. I feel your anguish..
Lets take a new look at it.
Instead of looking at it as a 'Virgin' build,
let's view it as a 'used' computer you just got in.
Tear it down.
Format the hard drive.
Clear the board (use the jumper)
Flash the bios to the latest driver.
1 stick of ram..
set up the bios ..
Load windows..
Load drivers...ect ..
Do one thing at a time...
do it well ..
move on ..
Stay Calm... hang in there.c.
05-11-2012 02:04 PM
05-11-2012 02:06 PM
05-11-2012 02:10 PM
