How to connect d-link router to wifi?
jamesmarkle11
Dlinkrouter.local is the web address you can use to access your D-Link router's settings. Once connected to your router's Wi-Fi network, simply type dlinkrouter.local in your web browser. Here, you can customize your Wi-Fi network name, password, and security settings. You can also find helpful features like parental controls and guest network options.
0 REPLIES 0
