How many storage unit controllers?
Chris_w
Not sure I'm in the right department of forum here so pardon me if this is off topic.
Having recently upgraded various drivers I noticed that I have 4 storage unit controllers installed of which 3 are NVIDIA nForce Serial ATA controllers that appear to be identical. The 4th controller is JMicron JMB36X. Do I really need 3 NVIDIA controllers?
4 REPLIES 4
HiVizMan
Level 40
Hello mate
Could you possibly list your hardware.
Chris_w
Certainly HiViz
Striker II NSE motherboard
Intel Core 2 Duo E8500 3,16 GHz / 3,17 GHz
NVIDIA Gforce GTX 480
RAM 4 GB
Windows 7 x64
Screen: Samsung SyncMaster 930 BF (dunno if this is relevant)
HiVizMan
Level 40
Ah dude that brings back happy memories. Striker extreme boards. 😄
The chipset is nVidea and that means that all the hard drive controllers will go via the nVidea controllers. You have nothing to worry about, simply ignore.
Chris_w
Great, thank you! 🙂
