02-22-2019 09:16 PM
02-23-2019 06:20 AM
trophybuck135 wrote:
I am trying to replace my battery and the cable won't separate from the motherboard. I can't figure out how to unlock it if there is a lock. Maybe I am not using enough force? See picture. Thanks
02-23-2019 07:48 AM
02-23-2019 08:11 AM
Thank you for the reply, I am referring to the middle cable with the 3 red, 1 white, 1 yellow, and 3 black wires coming out of the black battery.
Should I just tug that one too?
02-23-2019 08:35 AM
02-23-2019 11:39 AM
yep that is correct, my question is referring to the main battery. I am trying to replace the battery and I can't get the old one out because of that cable, it does not want to come apart from the motherboard. I think I read some of these cables have locks that I have to release, maybe by pinching the sides -- but that's not working here and it doesn't want to come off by just tugging.
I don't want to pull too hard and ruin the motherboard so I am hoping someone can tell by looking at it, if it has a lock or if I am save to just pull as hard as it takes.
02-23-2019 11:28 AM
