How do i clean my GL503VM from dust cooling system from dust?
HUNTER111
i asked last but got no answer so im trying againL
I have a GL503VM How do i open him up and clean its cooling system?
RedSector73
Level 12
Another reason I hate laptops.
Turn it off,
cheapo method :-
Use your trusty vacuum cleaner on suck or blow and clear out the dirt as best as possible.
run out to store that supplies air in can (buy, come back)
https://www.reviversoft.com/blog/wp-content/uploads/2012/12/Canned-Air.jpg
and get cleaning.
I would not recommend you open your system to clean out dirt. Unless you regularly open laptops and repair them.
I wasnt able to start a new thread but i wanted to ask if anyone of you who has asus gl503vm used a cooling pad ?
If yes, how much difference does it make in terms of temps?
Thanks for the reply x
