How can I purchase another DIMM.2 extension for my motherboard/NVME drives?
KyleTM
I want to procure a second DIMM.2 board for my motherboard, and would like to know how I can go about this.
Many thanks,
Kyle Manel
1 ACCEPTED SOLUTION
Accepted Solutions
Silent_Scone
Super Moderator
Your best bet is eBay, or somewhere of that nature. The risers are cross compatible so don't worry too much which iteration you purchase.
Silent_Scone
Super Moderator
