Although many existing memory kits for Z-170 will work fine on the new platform there are very few high binned kits for the new platform available at this time. Gskill is releasing several new kits, If you are planning on running memory with very high rated speeds it would be best to do your research and make sure you purchase the right kit for the best chance at having a good experience, keep expectations reasonable as not all CPU's can run memory at these speeds even if the motherboard and memory kits are rated for these very high speeds
http://www.gskill.com/en/press/view/g-skill-announces-new-ddr4-specifications--for-intel-kaby-lake-p...
