Help!?
EXILE157
Hi' everyone and thank you for taking the time reading and helping me with some info here.
- I don't ever O.C as I have no knowledge in that field, so I leave that to the professionals.
- I have about 2 months at most with my newly build gaming rig, specs can be read from my Signature Tag.
- Everything seemed fine until today 12/3/2017...I went to power up the system and immediately after turning on the power button the system shuts down? I repeated this steps a few times.
- I turned the switch off / unplugged the PSU and waited for awhile / I plug it back and turn on the switch, immediately the system turns on without me hitting the power button? I repeated this steps a few times.
- I then doubled checked all the cables / reseated the memories / I powered up the system now everything seems to be on and running, then I notice the GPU is lit up, but the fans are not running?
- I took out the GPU nothing changed, I then took both GPU out and again same thing everything else is running fine, but I noticed on the MoBo a (CODE 00)!?
- I had no GPU, no Memory and still the MoBo reads (CODE 00)?...Yet the NZXT CPU Cooler is running all fans in the case running?
- The MoBo is just stuck on (CODE 00) no matter what I do.
The issue I'm having is a (CODE 00) "Not in Use" > according to Manual.
I don't know what to do at this point, RMA? this 2 month in use Mobo?
*Lian Li PC-011D (Black) *i9-10900K *ROG Strix Z490-G *Nzxt Kraken Z63/Corsair QL Series *Corsair Vengeance Pro RGB 64GB (4x16GB) DDR4 *Corsair HX1200i *EVGA GeForce GTX 3080 Ultra FTW3 *Samsung 970 Evo M.2 1TB *Samsung 960 Evo M.2 500GB *Samsung 840 Evo Series 1TB SSD *Asus ROG Swift PG43UQ *Corsair K70 RGB *Corsair Dark Core *Corsair Gaming MM800 *Corsair ST100 *Razer Nari Ultimate.
EXILE157
WoW! 90 Views 0 Replies....Great Forum.
Chino
Level 15
The 00 QCODE can be caused by a lot of things. Start with loosening the screws for your heatsink a little. Also make sure you have installed your memory and GPU. If the system still halts with a 00 QCODE, proceed to check which QLED remains lit. 🙂
I already found out the issue, my cousin has a X99 board with same CPU, so I swapped it for testing and right away the same results came up on his Mobo (CODE 00) my CPU is dead!....RMA.
Thanks for the reply.
